Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Compute Failed
6 REPLIES 6
wendizhang712
311 Views, 6 Replies
Compute Failed
I have succeeded at using the sweep function for making the veins of a 3D model of wings. But there are particular veins that say "Compute Failed" or "profile does not intersect the path", even though they do intersect.
6 REPLIES 6
sutherland-
in reply to: wendizhang712
Hi @wendizhang712
Do you mind sharing the Fusion 360 file here so that we can assist you more efficiently?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
yes, here it is.
wendizhang712
in reply to: sutherland-
I would like to specify that is it these veins
wendizhang712
Here is my file.
sutherland-
Have you tried to use pipe feature instead of sweep?
Best regards,
Level  sutherland-
Member
I would use the T-Splines Pipe command.
It's a bit tedious to use, but less tedious than using sweep.  You will have to clean up your sketch, get rid of duplicate sketch points, and missing coincident constraints:
But, you can get what I think you want:
I only did this for a portion of this model (attached)
Jeff Strater
Engineering Director
