Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Complicated sheet metal contour flange
1 REPLY 1
lee.carmichael
139 Views, 1 Reply
Hey everyone, my best attempt to describe my problem is that I'm trying to run an L-shaped contour around a rectangular base flange. EXCEPT the rectangle isn't a rectangle - one of the long sides has two small and different angles to the short sides. AND where those angles meet there is a bend across the (non)rectangular base. Images below, .f3d file attached.
The problem enters at the miter.
It seems the angle between these faces is causing some discontinuity in the way Fusion identifies where miters go. But I'm new to sheet metal and may very well have no idea what I'm talking about.
Thanks for the help!
Lee
Labels (3)
1 REPLY 1
Sorry. Wrong forum. My bad.
Technology Administrators
