Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Comments not working
7 REPLIES 7
Message 1 of 8
dlpGVFNN
382 Views, 7 Replies
Whenever I try to open the comments tool add a comment to a file I get an error "Your file was not found - it may have been moved or deleted. ERR_FILE_NOT_FOUND"  It doesn't work on any of my files.
7 REPLIES 7
Message 2 of 8
jodom4
in reply to: dlpGVFNN
Hey @jeremy_lambert, can you offer some insight here?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 8
Hi there dlpGVFNN, did you by chance transfer this project from another hub?
-jeremy
Message 4 of 8
dlpGVFNN
Hi Jeremy
Its the same for all my projects. I don't think it has ever worked for me. I would like to be able to use it.
Message 5 of 8
jeremy_lambert
OK, it's not clear to me what the underlying issue is which is causing the error. I'll direct message you and see if we can't get on a call to take a closer look.
Message 6 of 8
tylerjoh
Did this issue ever get fixed? I'm having the same issue (Mac OS, v 2.0.12888)
Message 7 of 8
jeremy_lambert
in reply to: tylerjoh
Hi @tylerjoh, it seems the issue was that the session of Fusion 360 was in offline mode. You may want to check and see if Fusion 360 is online.
-jeremy
Message 8 of 8
nilloc
I also encountered this problem on all projects. I was working online, however there was a pending update. After installing and restart comments were available again.
