Fusion Support
Fusion 360 cannot launch and reinstall failed
4 REPLIES 4
mans4764
218 Views, 4 Replies
Dear Community Members and Support Team:
I hope this email finds you well.
I've been using Fusion on my computer for a while. Every thing worked well until one morning I can't open Fusion (the app is stuck in the launch window forever). The Fusion service utility showed up after a few failed trials. I clicked the repair button and Fusion launched properly after the repair.
Though, the problem appeared again this morning, and I tried to repair function again but it failed this time. I can recall a error message suggesting that "ADPClientService" is being used by other applications and reinstall failed.
I tried to uninstall Fusion and reinstall but this failed again, the log is attached to this post.
Thanks in advance for your time and patience.
Many Thanks,
Anyu Shan
4 REPLIES 4
CGBenner
in reply to: mans4764
@mans4764
Hello and welcome!
Do you still need help with this?  @RajkumarIlanchelian ?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
pdifflipp
I am having the same problem . yesterday I saved my project came back in this morning and had a Qt6Widgets.dll error.  I tried updating Fusion, but it said I had the latest version installed, so I uninstalled and tried reinstalling this morning and it has the "Problem installing Fusion 360" window popup.
mans4764
in reply to: pdifflipp
I solved this problem finally by uninstalling everything from Autodesk, reboot my computer, and install Fusion. This is a silly solution but I didn't find another way out yet
pdifflipp
It's not silly if it's a solution!!!! Thank You for the reply , I am willing to give this a try , and I am also dealing with an IT department at our workplace so I suspect they might have to do it.
Thanks, Paul
