I saw this elsewhere and its tripping a few people up, grbl has a line length of 50 or 70 depending on build and some of the GCODE "senders" for some reason send comments to the motion controllers without checking the line length maximum or even just ignoring comments.
maybe split it up into multi line comment or shorten the text to less than 50?
(When using Fusion 360 for Personal Use, the feedrate of rapid moves is reduced to match the feedrate of cutting moves, which can increase machining time. Unrestricted rapid moves are available with a Fusion 360 Subscription)
cheers
Solved by seth.madore. Go to Solution.
We're aware of this bug and hope to have a fix out for it very soon!
Has the problem been resolved and has there been a change to the automatic comment ??
Yes. An update rolled out a couple days ago to address this issue. Please restart Fusion and grab the latest update.
