Hi All,
Is it possible to combine bodies that are not touching each other? I want to merge all the bodies onto one body layer, like you would do in photoshop.
Mez
No, Fusion will not allow you to combine bodies that are not touching. Each body must have only one "lump". As @davebYYPCU says, Fusion does not support layers. The closest thing is to use Components to group bodies you want together, or body folders.
