Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Combine bodies
2 REPLIES 2
225 Views, 2 Replies
Combine bodies
Hi All,
Is it possible to combine bodies that are not touching each other? I want to merge all the bodies onto one body layer, like you would do in photoshop.
Mez
Tags (1)
2 REPLIES 2
davebYYPCU
Fusion doesn't use layers,
Any more detail available?
jeff_strater
No, Fusion will not allow you to combine bodies that are not touching.  Each body must have only one "lump".  As @davebYYPCU says, Fusion does not support layers.  The closest thing is to use Components to group bodies you want together, or body folders.
Jeff Strater
Engineering Director
Technology Administrators
