I'm new to fusion 360, i'm trying to learn modelling from picture from the internet but I'm having this small problem of canvases being "too translucent" even after adjusting opacity to 100% and the picture imported has no transparency effects.
That is because you have the component "case" active, and by default, other components (including the root component, which is where your canvas is) are "dimmed" to better show the active component:
If you don't like this, it can be disabled by unchecking this setting in Preferences:
Thank you Mr Strater. I had the same issue and couldn't find an answer. Spent hours trying to find it until I saw your post. I find it a bit annoying that Fusion won't allow the user to insert a canvas image in a component other than the root component but hey, now I know. Thanks again.
