Fusion Support
cannot open the program " cannot connect to internet"
4 REPLIES 4
391 Views, 4 Replies
Here is a screenshot of the problem and my log files, i have done almost all the troubleshooting several times and cannot come right, this comes up immiediately after install. thank you
4 REPLIES 4
jodom4
Hey christopher.austin,
Sorry for the inconvenience. This is a known issue that the development team is currently working on. They're hoping to include this in the next hot fix.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
matt.pooley
Hi Christopher,
This actually looks like a different issue to the one a number of people saw last week. Taking a shot in the dark, could you try renaming a file while Fusion is closed to see if it helps, the file is %APPDATA%\Autodesk\Neutron Platform\Options\NMachineSpecificOptions.xml
If that doesn't help, can you try testing on a different network to see if there is something specific to your network that is happening ?
Matt
On Behalf of the Fusion Dev Team
in reply to: matt.pooley
I will try opening it on a different network, but the file you asked me to rename does not exist in that file loctation.
Just to update you, the problem seems to have sorted its self out, i havent checked it on a different network or changed any setting, just tried it 2 days later after the problem and it worked and was able to sign in and start.
Reagrds
