Here is the link to the file in question: https://a360.co/2PQvozu
I have a multitude of files just like this one where I perform the same operations in each, for some reason this extrusion keeps producing a Missing Profile warning...
The Body in question is the last in the timeline within the "BuildOut_BODIES" component, and the source profile is the enclosed profile in the "Base" sketch within the "BuildOut_SKETCHES" component.
I'm clearly missing something... any help appreciated.
Thanks!
Solved by jhackney1972. Go to Solution.
I could not find the error in the profile either but I wanted to suggest a quick solution to move forward. The profile you have is on one of the component origin planes. Select that plane, make a new sketch and project all of the problematic sketch into the new sketch. This will give you a new "valid" profile so you can continue designing.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Yup... worked!
I cannot believe I didn't try that myself, so thank you for getting me there.
