Fusion Support
Can't see drawing template after update.
4 REPLIES 4
JKNIGHTSKKJT
292 Views, 4 Replies
I am no longer able to see a drawing template when opening a drawing. Even old drawings will not show parts or the title block. I've made sure the bodies are not invisible. Anyone else have this problem after the update?
4 REPLIES 4
Pramod.kadam
in reply to: JKNIGHTSKKJT
@JKNIGHTSKKJT ;
Apologies that you are facing an issue and thanks for reporting.
Do you mean all views and other objects not visible in drawing sheet canvas?
Please try the following:
  1. Clear local cache  - Check if this helps.
  2. If above doesn't work, try Clean Installation.
  3. Share log files if above doesn't work.
Pramod Kadam
Product Owner
Fusion 360 Drawings
JKNIGHTSKKJT
in reply to: Pramod.kadam
Thanks for your quick response. I've tried the things you suggested, and it is still not working. Iam able to open a drawing and run my cursor over items and see them but i can't see the whole thing. I am able to print the drawing and everything shows up just fine...
JKNIGHTSKKJT
I re installed fusion once again and now it says i may have an issue with the graphics card. I will take a look at this and let you know if I can figure anything out. Thank you.
liang_chen
Please update the driver of graphics and check if it helps.
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
