Announcements
Can't render locally all of a sudden
jrTBEJE
jrTBEJE
After submitting local render, nothing appears in the render gallery in progress.....for any designs...nada.
Fusion 360 2.0.16265 x86_64 [Native]
Active Plan: Startup
macOS 13.4 (22F66) on MacBookPro16,1
Never have had this happen.
gymnyan-man
Hello.
A bug has been confirmed that local rendering is not possible on MacOS.
It's not your environment's fault.
It seems that there is no choice but to use cloud rendering or wait for an update
MLeskowUAKV8
We are having the same issue here. Are they reimbursing all points for renders? As we make renders often for our customers and this is an Autodesk issue. Please advise.
MLeskowUAKV8
This is marked as solved but it isn't solved. As the solution given is to use points to do renders and that isn't a solution to the issue. Are they reimbursing the points? If they are then this work around is acceptable for now but now it takes 20 minutes to complete a 3 minute render.
gymnyan-man
Today's update has fixed this problem.
If the rendering fails to perform, it is assumed that no points have been consumed.
Please contact Autodesk if you have any money problems as I am not an employee.
MLeskowUAKV8
I can confirm this morning's update has appeared to resolve the issue. When support told me Thursday that they hoped to have the update out Monday, I was relieved to here it was so soon.
