After submitting local render, nothing appears in the render gallery in progress.....for any designs...nada.
Fusion 360 2.0.16265 x86_64 [Native]
Active Plan: Startup
macOS 13.4 (22F66) on MacBookPro16,1
Never have had this happen.
Solved by gymnyan-man. Go to Solution.
We are having the same issue here. Are they reimbursing all points for renders? As we make renders often for our customers and this is an Autodesk issue. Please advise.
This is marked as solved but it isn't solved. As the solution given is to use points to do renders and that isn't a solution to the issue. Are they reimbursing the points? If they are then this work around is acceptable for now but now it takes 20 minutes to complete a 3 minute render.
I can confirm this morning's update has appeared to resolve the issue. When support told me Thursday that they hoped to have the update out Monday, I was relieved to here it was so soon.
