- Mute
- Permalink
- Report
Hi all,
I have a commercial subscription to fusion 360 (started in Jan) but switched to a startup version in order to do some 4th axis stuff. It was all working fine (a few weeks ago) and using it today, I can't get it to post. I still have all of the options for orientation etc, but no output for machining. I'm not sure what changed but I need to get it working. If I have to go to ultimate I will but would like to get a little more time from the startup license. Not sure this the problem, but here is what the editor says when I try to post:
: Configuration: Generic Tormach PathPilot
Information: Vendor: Tormach
Information: Posting intermediate data to 'D:\post process\1001.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, September 29, 2017 8:24:17 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41465
Configuration path: C:\Users\james\AppData\Local\Autodesk\webdeploy\production\6b014ce3e90b393cb8b4459a016fe88667a42a91\Applications\CAM360\Data\Posts\tormach.cps
Include paths: C:\Users\james\AppData\Local\Autodesk\webdeploy\production\6b014ce3e90b393cb8b4459a016fe88667a42a91\Applications\CAM360\Data\Posts
Configuration modification date: Monday, August 07, 2017 7:45:28 PM
Output path: D:\post process\1001.nc
Checksum of intermediate NC data: a39a7d8d3a45730f55f8b7cb121dedc3
Checksum of configuration: 7831c1a03d5910cf8a7ccfd0fca1b7ee
Vendor url: http://www.tormach.com
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.3257
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, September 29, 2017 8:24:17 PM
Post processing failed.
Does this look like a license problem or something else?
On another issue, why do I not have access to an archive format for exporting? I have iges, step, etc, but no f3z or f3d. Any ideas how I can export files that fusion will have history on, rather than the dead versions? If I need to do clean install of this I would prefer to backup first. but I don't want to lose all the fusion file history.
Thanks, James
