Hi community! I'm trying to achieve this on F360. The scope of this design is generating a circle pattern of these generatrices, but making each one of them sequentially thicker. If the width of my first generatrix is 0.5(n), I want the next one to be (n+02)= 0.7, and so on until I get to 50 related widths. I want each curve to get thicker. I'm a little bit lost on the procedure. Should I first create a rectangle W: 0.5, and then add the width parameter?. And afterwards, when I want to generate the circular pattern of this, is there an option in which I could change the following widths to generate a radial array?
I hope I was clear, it's a really complicated task to explain.
please share a sample file
File > export > save as f3d on local drive > attach to next post
günther
