Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Can't figure out why fillet isn't working
2 REPLIES 2
harrison.friedes
184 Views, 2 Replies
This is a body that was originally converted from a mesh and then extruded further, which I thought could be part of the issue, but the other edges fillet fine while this one doesn't.
Fusion file attached below!
2 REPLIES 2
It is caused by all the left over faces from your Mesh conversion.  Replace the top surface with a solid and your fillet will work just fine.  Model is attached.  Follow the timeline to see how I did it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Solved, thank you! I'll have to study up on Surface Patches to better understand how to replicate on my own. Really appreciate it.
Technology Administrators
