Can't combine bodies
petr.koutecky15
petr.koutecky15
Hello. Does anybody know why I can´t combine bodies 3 and 12 of my USB camera holder? I can´t even extrude from the body 12. I tried to make more space between the two surfaces of the body 12 so they don´t touch like they do now but it didn´t help.
Thanks.
g-andresen
try it as shown in the screencast.
günther
I just see that the extrusion to the object is also possible with your sketch 6 and plane 1.
Therefore sketch 7 and plane 2 (attached file) are not necessary.
petr.koutecky15
Thanks, I didn´t think of that solution by extruding to plane. Brilliant 🙂 Anyway do you have idea why it didn´t work by my approach just in case I will have similar problem? Why that combining/extruding didn´t work?
g-andresen
I suspect that the "error" is caused when converting the stitched surfaces to solid body.
günther
WHolzwarth
It's tricky. I think, Günther's file doesn't match the intended shape.
Here's my final attempt. Perhaps the square cut needs some change, I didn't compare that.
Walter Holzwarth
shawnmacYSNVY
Observer
Observer
In case some poor soul goes searching the forums for the problem I had, there are many ways it seems that combine operations can be screwed up.  One is where it actually works but looks like it doesn't.  If you want to JOIN bodies with the Combine tool, make sure you UNCHECK "keep tools".  If you don't what will happen is the bodies will join as you commanded, but the original bodies you used, the "tools" will remain.  First, this means that all the bodies you wanted to join will stay in your browser and make you scratch your head saying "why the heck didn't it work???"  Second, it means that you will have, in effect, two copies of the same shape perfectly "phased" into each other, which is extremely difficult to see unless you zoom in real close - then you will see some aliasing on the lines.   Its even hard to see with Inspect >> Section Analysis, but you will notice some wonky "half lines" that happen when its trying to show both the joined body and the "kept" body at the same time.
