Fusion Support
Can't choose/edit the # of T-Splines for a cylinder in forms
11 REPLIES 11
Message 1 of 12
M.Keith.Thompson
395 Views, 11 Replies
When I create a cylinder, it automatically creates 8 T-Splines around and 4 high.  After I select the center point and the diameter it creates it without allowing me to choose the # of T-Splines.  Editing will not allow me either, the options are gone.  I have watched videos on how to do this, but the software is not working as described.
11 REPLIES 11
Message 2 of 12
Set diameter,
but do not set length with the mouse,
fill in the dialogue box first, including length.
Might help...
Message 3 of 12
Yeah, that's the problem that dialogue box never shows up;  I select Form, Cylinder, Plane & Center point with the mouse; drag the mouse slightly to get the diameter box, enter the diameter from keyboard then press Tab literally nothing happens with tab, Enter creates the cylinder as described earlier
Message 4 of 12
well let me be more accurate, the cylinder dialog box shows up, but with only the Direction option (One Side, Symmetric); not the box with the options listed in your image
Message 5 of 12
So you are given the Dialogue box as depicted?
Tab in Dialogue boxes?  Never tried it, but I don’t think that works as expected.
….. Set diameter, with mouse stretch - Dialogue appears - select dialogue box field to alter,
enter particular,
do not press enter / Ok until all the fields been altered.
Might help….
Message 6 of 12
@M.Keith.Thompson - Please show a screen capture of what you see with the cylinder dialog, or better:  a video.
Jeff Strater
Engineering Director
Message 7 of 12
Yes,  followed DaveB directions, but only the "Direction" field is shown
Message 8 of 12
And now, as instructed, just click with the right mouse button ...
Message 9 of 12
@TrippyLighting - I think you mean "left mouse button".  Here is a quick video showing the command progression.  As soon as you click for the circle position, the rest of the dialog comes up:
Jeff Strater
Message 10 of 12
Oops! Yes that's what I meant!
Message 11 of 12
That worked! thank you so much; been very frustrating
Message 12 of 12
I agree that this can be frustrating. A bit of UI work on Autodesk's side would certainly be helpful in making it less so.
