Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
BUG: Mirroring feature Extrude (from object)
4 REPLIES 4
kristianY3VSG
243 Views, 4 Replies
Mirroring an Extrude (from object) feature doesn´t work properly: though the preview shows the correct (wanted) geometry mirrored by the mirror plane, after OK the feature is mirrored by the "from object" point. In the past this worked well, I discovered the bug while modifying a design I haven´t opened since a longer time (don´t remember, when the last modification was done).
My question: Is this behavior intended (and I have to rework all mirrors) or a bug (and I can hope, it will work correctly one day)?
Thanks, Kristian
Demonstration example:
1. Extrude to be mirrored (from object = highlighted point)
2. Mirror features (extrude + fillet) - preview
3. Mirror features (extrude + fillet) - result after "OK"
4. Intended result, now achieved by Mirror (faces) selecting the affected features (Extrude, Fillet), formerly done by Mirror (features). But in many cases this trick doesn´t work - depending on the actual geometry.
4 REPLIES 4
ryan.bales
in reply to: kristianY3VSG
I can sort of reproduce this, but it would be helpful to have this file when the mirror is broken.
I get a successful mirror outcome when switching to Optimized:
I never got the partial mirror at the wrong distance but it does fail to mirror with Adjust on.
Ryan Bales
Fusion 360 Product Support
kristianY3VSG
in reply to: ryan.bales
Oh, thanks! I didn´t notice these options, wondering now, how this setting could change! Maybe it´s a new feature added after my last work with the design. Now I tried some mirror features realizing, that some need to be set to "identical", the other options don´t work (error - red feature icon). The preview always shows the "optimized" version.
Well, changing this option is a much easier way than searching an optional solution for each of many mirrors, I´m happy with this.
Attached see the f3d of the shown demo. Here both Optimized and Identical do work.
PS: Now I discovered, that this problem occures for the "Pattern" feature too (no warning or error, just the instances aren´t created), so I have to check manually all of them too 😟
ryan.bales
I do think this is more common for pattern, especially when using features. I typically pattern faces, bodies, then features in that order if possible.
Ryan Bales
