I just struggle with browser.
Here is link to screencast:
When clicked to collapse or expand the component tree then the "triangle button" disappear. Then to "expand" I have to click yellow bulb.
This is related to long components or assemblies names.
This is very annoying to select and productivity is going down. ๐
Hopefully you can recreate this.
Solved by HughesTooling. Go to Solution.
I think this problem happens when you have a long name in the browser that's wider the the browser dialog. The workaround is drag the handle on the browser and make it wider.
Mark Hughes
Owner, Hughes Tooling
Yes I just checked and it's the same bug I reported here a couple of years ago!
Mark Hughes
