Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
BUG: Browser collapse weird behaviour
3 REPLIES 3
327 Views, 3 Replies
I just struggle with browser.
Here is link to screencast:
http://autode.sk/2pmRbSz
When clicked to collapse or expand the component tree then the "triangle button" disappear. Then to "expand" I have to click yellow bulb.
This is related to long components or assemblies names.
This is very annoying to select and productivity is going down. 🙂
Hopefully you can recreate this.
3 REPLIES 3
HughesTooling
I think this problem happens when you have a long name in the browser that's wider the the browser dialog. The workaround is drag the handle on the browser and make it wider.
Mark Hughes
Owner, Hughes Tooling
Yes I just checked and it's the same bug I reported here a couple of years ago!
https://forums.autodesk.com/t5/design-validate-document/problem-moving-light-bulbs/m-p/5771313/highl...
Mark Hughes
in reply to: HughesTooling
Workaround works great. Thanks.
