Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Bug Attempting to Rename Joints & Save
1 REPLY 1
278 Views, 1 Reply
We've found an interesting bug with Fusion 360. If you open a file with top-level joints (may work with joints in non-linked components, but I didn't have time to test), and rename a joint (click twice in the browser), you then cannot save the file as Fusion 360 doesn't detect the change.
The only workaround was to make some other trivial edit to the file and then save.
1 REPLY 1
karina.harper
Hi @Anonymous
I was unable to recreate this on my side, could you post a screencast of the behavior?
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Technology Administrators
