Fusion Support
Bridge Tool Doesn't Let Me Select Edges
2 REPLIES 2
jburickJUFQ4
96 Views, 2 Replies
Hello!  I am trying to follow a Fusion 360 tutorial where I am trying to bridge a hole in the Form environment.  I can select faces, but not edges.  In the tutorial the user is selecting edges.  I'm clearly missing something here - any help is appreciated!
2 REPLIES 2
Sometimes it helps to change from perspective into orthographic view.
Also, make sure your selection filters are set properly:
jburickJUFQ4
in reply to: jburickJUFQ4
Thank you I will give that a try!
Technology Administrators
