Hello! I am trying to follow a Fusion 360 tutorial where I am trying to bridge a hole in the Form environment. I can select faces, but not edges. In the tutorial the user is selecting edges. I'm clearly missing something here - any help is appreciated!
Solved by TrippyLighting. Go to Solution.
Sometimes it helps to change from perspective into orthographic view.
Also, make sure your selection filters are set properly:
