Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Bridge Tool Doesn't Let Me Select Edges
2 REPLIES 2
jburickJUFQ4
143 Views, 2 Replies
Hello!  I am trying to follow a Fusion 360 tutorial where I am trying to bridge a hole in the Form environment.  I can select faces, but not edges.  In the tutorial the user is selecting edges.  I'm clearly missing something here - any help is appreciated!
2 REPLIES 2
Sometimes it helps to change from perspective into orthographic view.
Also, make sure your selection filters are set properly:
jburickJUFQ4
in reply to: jburickJUFQ4
Thank you I will give that a try!
