Here is the design:
As you can see, nothing special. All of the sudden everything went invisible. Recomputing didn't help.
What's even more bizarre is that if I create a Sphere, that when I need to select the plane to create the object, everything becomes visible, but as soon as I click and have to define its radius, everything is invisible again.
This is on the latest Fusion360 version, on my Macbook Pro running Sierra 10.12.6. Radeon Pro 455 video card.
Solved by paul.clauss. Go to Solution.
Hi @Anonymous
Thanks for posting! I noticed that nothing was shown when I went to download your file, but when I opened it, I noticed that the visibility of the top level component was turned off. Turning it on allowed all the bodies to be shown, as in the screencast below. You can see the lightbulb is turned off in your screenshot at the top left-hand corner.
Hopefully this helps!
