I am trying to blend/transition the 3/4 radius into the 5/32 radius on the edge of this part. See attached. Any ideas would be greatly appreciated.
Solved by HughesTooling. Go to Solution.
Use a variable fillet like this. You need to pick the midpoint then set the radii. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
You can use a Lofted surface from the edge of the large radius to a radius, on a plane of your choosing, and then use that to Split the body. Then you just remove the extra body and mirror. The location of the sketch plane determines the steepness of the transition. There is of course a limit. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
