I ended up getting help from Shaper's support team and they solved my problem on my mac. Now, the Shaper plugin is working perfectly.
My situation: I was able to run the Shaper plugin install without any issues on my mac, but once the installation finished, I did not see the shaper icon in Fusion 360 on my Tools ribbon. Turns out that the ShaperUtilities.bundle file is copied to 2 folders as part of the install process. For whatever reason, this file was not properly installed to both folders after the setup.
To resolve my issue, I just had to manually copy (make sure you copy and don't accidentally move the file!) ShaperUtilities.bundle from one folder to the other folder. Using the details below, check the 2 locations for the ShaperUtilities.bundle file and copy it to the other folder as needed. Copying the file solved my issue!
Here are the 2 locations where the ShaperUtilities.bundle file needs to be located for the plugin to work properly. If you only find it in one of the folders, simply copy it to the other folder. It needs to be in BOTH folders for the plugin to work properly.
- [User] > Library > Application Support > Autodesk > ApplicationPlugins
- Library > Containers > com.autodesk.mas.fusion360 > Data > Library > Application Support > Autodesk > Application Plugins
For anyone unfamiliar with finding and navigating these system folder areas on the mac, in the Finder app on your mac, click Home from the Go menu to get to the [User] location referenced in the first bullet above and you can navigate the folder structure to find your way to the ApplicationPlugins folder. And click Library from the Go menu to get to the Library folder and you can navigate the folder structure to find your way to the Application Plugins folder.
