Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Annotation Settings on Drawing are not showing
6 REPLIES 6
wdonowho
3868 Views, 6 Replies
How to I get the Annotation Settings to show on my Drawing pages.  I've looked, but obviously I am missing something.  Thanks.
6 REPLIES 6
Hi @wdonowho ,
There are some changes/enhancements in 2D Drawing, linked below.
https://www.autodesk.com/products/fusion-360/blog/may-2020-product-update-whats-new/#2D_Drawings
Document & Sheet Setting are under browser nodes;
Thanks & regards
Amit Suryawanshi
Amit Suryawanshi
SQA Fusion 360
in reply to: amit_suryawanshi_fus
Nope. My only available option in the Design environment, under "Document Settings," is Units. None of the drawing annotation options, such as font size, as shown in your roadmap screenshot, are visible under "Document Settings" or anywhere else in the program (Drawing environment, Preferences, etc.). Within the Drawing environment the option to edit the title block only permits editing of content, not format). A default font can be chosen under Preferences, but not the font size.
Something has gotten lost in the shuffle.
toby2SBPJ
in reply to: wdonowho
BUMP!
As of recent, my drawings annotation-settings shortcut has gone missing.  I can't change font size or line weight.  Please help.  Do not consider this issue close.  ThanksAnnotation 2020-06-08 124506.png
The "Like" and the "Solved by @amit_suryawanshi_fus " do not reflect the Open nature of this issue.
Toby
andrew.de.leon
in reply to: toby2SBPJ
Hi @toby2SBPJ,
The solution provided by @amit_suryawanshi_fus is correct. As he says, in the last update we moved these settings from the bottom of the screen into the browser. Document Settings contains what used to be Annotation Settings and Sheet Settings contains Sheet Settings. Here's a full screen view of the changes.
Cheers, Andrew
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
toby2SBPJ
in reply to: andrew.de.leon
Thank you!  user @Anonymous and I may have both been confused by @amit_suryawanshi_fus not including the Document Settings expansion in his screenshot.
Thanks a bunch.
Sincerely,
Toby
toddhsnider
Not sure why it's not in the Sheet Settings but the SOLUTION for me, at least was under Document Settings>Dimension Units.
-Right click Dimension Units
-select Change Dimension Units
-in the Document Settings Window select Fractional in the pull down menu for Dimension Format
