3D Print opens g-code viewer not the slicer
since two days (I updated my IMac to MacOS Ventura 13.3.1) I can no longer export my own models via "3D print" into any slicer. For several years...no problem at all. What happens:
I have set Prusa Slicer (tried different versions) path into "3D print" menue. As soon as I hit "ok" it opens the prusa g-code viewer (of course with no model in it...only the program) where it normally shoud open the prusa slicer to show the stl model.
When I set the Cura path instead it opens Cura but shows nothing.
Weired thing is, that any model I originally imported (form thingiverse or prusa printables) works totally as it should...means just opens the slicers to go on.
I really don't know if this is an fusion or MacOS issue. Friend of mine with same OS works fine. I found another guy in prusa forum having the same problem...can't contact him to see if he made it somehow.
My Fusion is online, reinstalled and Mac has the prusa slicer (standard) to open stl's.
I tried everything that came to my mind...no I need help please!
