My fusion 360 3d perspectives are reversed. Items closer to me should be larger then those further away. It's as though the vanishing point is towards me rather then away. Example: if I render a 3d rectangle, the side nearest me looks farther a way then the side a way from me.
Please view attachment.
Right click the view-cube and check if you are in Orthographic projection or Perspective.
Thank you so much for your fix. I'm surprise this is not mention in the many tutorials, being not obvious.
If this answers your question, please use ACCEPT SOLUTION to assist other users later.
