Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
3d Perspective is wrong
3 REPLIES 3
floydrevans
244 Views, 3 Replies
My fusion 360 3d perspectives are reversed. Items closer to me should be larger then those further away. It's as though the vanishing point is towards me rather then away. Example: if I render a 3d rectangle, the side  nearest me looks farther a way then the side a way from me.
Please view attachment.
3 REPLIES 3
Right click the view-cube and check if you are in Orthographic projection or Perspective.
Thank you so much for your fix. I'm surprise this is not mention in the many tutorials, being not obvious.
If this answers your question, please use  ACCEPT SOLUTION  to assist other users later.
