Zoom Functionality for Apple Magic Mouse
chisholm_gavinl
Observer Observer
Message 1 of 15
chisholm_gavinl
Observer
Observer
Hey Fusion, built-in zoom navigation functionality would be an incredibly helpful feature to add for Apple users with a Magic Mouse. Can this be expected anytime soon, or is there a workaround?
Replies (14)
Message 2 of 15
tyfyb
Another user here in need of this feature. The trackpad surface on the magic mouse is very useful for other applications, but I have to switch to a second mouse with a wheel when using fusion.
I also use a 3dConnexion space mouse but would still benefit from the magic mouse to have built in zoom.
Message 3 of 15
autodesk_com48
Community Visitor
Community Visitor
ug...  why no apple mouse suppot still? apparently zoom is quite useful!
Message 4 of 15
Mattbakker
Community Visitor
Community Visitor
Un check gesture based view navigation under general preferences
Message 5 of 15
tyfyb
@Mattbakkerthat does not solve the issue.
Gesture based view navigation un-checked
- Drag on magic mouse = Zoom
- Orbit is not possible with mouse
- Pan is not possible with mouse
Gesture based view navigation checked
- Drag on magic mouse = Pan
- Drag on magic mouse + Shift = Orbit
- Zoom is not possible with mouse - Ideally this would be Drag on magic mouse + Command = Zoom
Autodesk team:
PLEASE PLEASE make an update to allow for a zoom shortcut with magic mouse/trackpad such as the following:
- Drag on magic mouse + Command = Zoom
Also hire me to join your UX team. I am a big fusion fan but see people around me choosing other options because of the poor usability that you can fix with the right help.
Message 6 of 15
Mattbakker
Community Visitor
Community Visitor
Just got a new Mac mini M4 Pro and set it up today and it worked for me
Matt
Message 7 of 15
tyfyb
As stated in my previous post, zoom works with gesture based view navigation un-checked, but this disables all other functionality for viewport navigation.
Solving one issue only to cause another is not a solution. We need zoom, pan, and orbit controls to all work with the magic mouse under the same settings.
This issue persists. Autodesk team, please help us address.
Message 8 of 15
Mattbakker
Community Visitor
Community Visitor
Ok i understand
Message 9 of 15
anthonyvallone
Community Visitor
Community Visitor
CMD + (Swipe Left/Right) will zoom in/out.
This is with Gesture Based Navigation checked
Message 10 of 15
tyfyb
Interesting. It works but very laggy when going between orbit and zoom. It's also not the typical zoom interaction you see on other software. This would ideally be updated to the unused CMD + (swipe up/down) for zoom which is more in line with other software. Can't think if a single 3d product that uses left/right for zoom so why do it here?
Message 11 of 15
nikolaj_t
I usually use a Logitech MX Master 3S mouse with my iMac for Fusion 360, mainly because the Apple Magic Mouse is so frustrating to use — scrolling pans instead of zooms. When I hold Command (in Fusion) or Control (like in SolidWorks), scrolling does zoom, but it’s extremely laggy and almost unusable.
When I’m traveling, I often don’t bring the Logitech, and I really miss having proper zoom control with the Magic Mouse. On my MacBook Pro touchpad everything works perfectly — pan, zoom, and orbit are smooth.
It would be great if Fusion had an option to switch “Scroll = Zoom” instead of “Scroll = Pan” for Magic Mouse users.
If anyone knows a workaround (macOS setting, modifier key, or third-party tool), please share.
Message 12 of 15
tyfyb
Oh wow it's fixed. Today I used the zoom gesture I use on all other apps (command + swipe up) and it works! Very laggy but at least it technically works. Thank you!
Message 13 of 15
armenf
Community Visitor
Community Visitor
Thank You
Message 14 of 15
msh547
Community Visitor
Community Visitor
What are the settings you use to accomplish this?  I am still stuck in the hell of not being able to Zoom or not being able to Orbit/pan
Message 15 of 15
alc1959
Community Visitor
Community Visitor
Yes please. The Magic Mouse is all I have at the moment; can't we get an easy pan and zoom via the mouse without clicking into menus?
