Wrap toolpath
Wrap toolpath
leonnolte
Message 1 of 15
Wrap toolpath
leonnolte
Hi all
I don't have the rotary extension. I want to use the wrap tool path in my Fusion 360. I am using my Fusion 360 to design molds for my big game lures to mill on my CNC machine. I have a 4 axis machine with the 4th rotary axis on the x axis.
I will post the link here.
This is a fish head inner part of a marlin lure. It will be cast inside the head of the lure. I need to to mill this . I can't get the cylinder to run on the x axis....the way it should be. If this is not possible to do in wrap tool path then i must find another way. The extensions is to expensive for my that will only use rotary for maybe 3-4 times a year
Replies (14)
Message 2 of 15
seth.madore
Wrap toolpath only works for cylindrical components, which this one doesn't seem to share any similarities.
It looks like the answer for you would be a 3 axis toolpath in multiple Setups.
Seth Madore
Message 3 of 15
leonnolte
Hi
Thanks for the advice. I will try the 3 axis and see how far i get
otherwise i have to hand shape
Message 4 of 15
seth.madore
Based on your images, I'm seeing 3 mill operations;
1) Establish the end "square-ish" section and qualify some outer dimensions
2) Machine one side as deep as possible
3) Machine some soft jaws, hold onto what's been machined and finish the second side.
Now, there may be some geometry that prevents that from actually working. Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
Message 5 of 15
leonnolte
Hi thanks for your reply. To late now. Will do in the morning
Message 6 of 15
leonnolte
Thanks will do so tomorrow morning
Message 7 of 15
leonnolte
Hi Seth.
I have attached the file you where asking for
Thanks for you help
leonnolte
Message 8 of 15
seth.madore
Try again please, the file is empty 😞
Seth Madore
Message 9 of 15
leonnolte
Hope this will work
Message 10 of 15
leonnolte
Export only gives me the one option of .f3z. ???? and it is not working
Message 11 of 15
leonnolte
This is how the file get saved on my Downloads if i export the file.
Message 12 of 15
seth.madore
.F3Z is a valid file, that just means you have linked components or a Machine Configuration (and machine) in the Setup.
Seth Madore
Message 13 of 15
leonnolte
Try this one ..
Sorry for aal this
Message 14 of 15
seth.madore
Yep, we have a winner!
So, looking at your file, the first question I have is; what's the material and how many of these do you plan on making?
Seth Madore
Message 15 of 15
leonnolte
Hi
I would mill it out of aluminum. This aluminum peace will be my master that i will make a silicon mold of. This mold i will use to cast many inners with for eventually the inners will be decorated and cast into the lure heads.
leonnolte
