Bug Report: Cannot Complete Extrusion to Object, the Extrusion Profile Falls Outside of the Boundary of the Selected Body
Please check out the attached Fusion 360 model to see the bug.
I'm tying to make a pretty simple hollow form with a shadow line, loosely following this tutorial video. This should have taken me 5 minutes, but of course Fusion has a bug that makes it impossible to do the simple thing that he does in OnShape in the video, and the error message it gives doesn't make any sense with respect to what's happening
I just made a simple shape, then I hollowed it then sliced it with a curved surface. Then I made a sketch where I projected the walls and made an offset, then I just tried to extrude To Object selecting the face at the top of the walls so I could cut a groove into it to make a shadow line. Fusion 360 gives the error "Cannot complete extrusion to object. The extrusion profile falls outside the boundary of the selected object."
It's impossible that this profile falls outside of the boundary of the selected object because the profile is literally a projection of that exact object! Either Fusion failed to exactly replicate the edge when I projected it to the sketch, or it's failing to properly extrude the profile. Either way, somehow Fusion is introducing an error where these two edges no longer match, even though they should be literally mathematically identical since one of them is just a projection of the other one. Even if I simplify the sketch and remove the offset and only project the top surface of the wall to the sketch then try to extrude that sketch To Object and select that top wall surface I get the same error. Seems like there's some fuzzy math going on under the hood where there shouldn't be.
Anyway, this is a huge blocker for me, as shadow lines like this are very useful in designing enclosures and parts that fit together, and this bug makes that impossible without some crazy workaround.
