Working with objects imported in Rhino format
- Mute
- Permalink
- Report
I am trying to develop a workflow around importing a design created in Vectorworks, and exported as Rhino. I am currently opening the Rhino file in Fusion 360, then saving it, and inserting into my Fusion design. The objects come in as a long list of bodies. I would like to be able to move related bodies into a group, or component, or even convert them into a single object or something so that they are more manageable. I have only succeeded in creating a selection set, but it is slow because it contains 1600 objects (from maybe 100 bodies). I have tried everything I can think of to get these objects into a component, or create a group from them.
I just read about 'combine', and thought that I was having a small amount of success with that, but realized that it is merging the individual bodies (which is why it is called combine, I guess). Is there not a way to take a selection of bodies, and move them into a component? Dragging these bodies into a component does nothing.
The imported bodies from the rhino format look perfect, so if possible I would like to use that format. I haven't had the same luck with importing a dxf, I often have missing bodies on the import.
