@TimelesslyTiredYouth
Agreed with you that nothing gets done with a poor attitude and AD wants to keep this a non-volatile forum but I need to empathize with @alienjuggernaut a bit. The American workforce is using this software for professional applications and it just DOESN'T perform. They've tried re-inventing the wheel and they've created a cheap monster. There is no file I have or example that I can provide, this is just how the software works, I know because I teach it daily. AD is chasing their tail with Cloud based CAD/CAM software as @alienjuggernaut pointed out. I have been using it for the past 10 years professionally and it's so mind-boggling the issues that come up from just trying use basic stuff. And Autodesk's answer? Just adapt to it.......
Here's a few things that just make that me cringe:
1. CAD/CAM interface. Since the stupid Cloud links everything and everyone together, machine simulation files are nothing more than a .F3D file that has machine data attached to it. I recently tried to SIMPLY delete a file that was once linked to a machine sim and it said it's referenced somewhere else. I checked every workspace, setup, cache, HUB, used in, etc. It didn't exist anywhere. I made a support case with AD about it. They said that it can't be deleted and I would have to Archive it because the way the Cloud saves versions of models. This has happened multiple times to multiple customers of mine. Definition of insanity when you tell a customer that they can't delete a file. MasterCAM? FeatureCAM? Esprit? PartMaker? All have a separate file extension for machine sim files.
2. You can't open multiple instances of Fusion or you will have poor performance. Why can't Fusion? Because of Cloud project synchronization is always on if your working online, license validation which is linked to being online, and the stupid version control that is awful.
3. When you do a simple Save As, if you're not already in the project or folder in the Data Panel, it will save to a different location. The user has to hunt around the data panel to find the folder that it's in then do a Save As when they have hundreds if not thousands of files. Network based CAD/CAM software you just do a Save As and it shows you right where the file location is.
What everyone is getting at is that developing Fusion to be Cloud based was a huge mistake which a lot of people warned about over 10 years ago. If they made a network version of this software I would buy several seats and plug-ins because it would be pretty rad. Eventually everything will be Fusion down the road. They are already getting rid of HSMworks for Solidworks which is a massive F-you to millions of customers because there is no file migration plan and the need to start over in Fusion. Literally telling companies to re-design years of product in Fusion. How will that work for customers who design and manufacture ITAR/government contracts using Solidworks? Autodesk doesn't give a rats.
