- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm simply trying to cut a corner off of a 3D extruded object. When I turn on the object and create a new plane on one of its surfaces, then cut a piece off the corner by snapping the sketch line to each edge and extruding (i.e. cutting) the piece off the corner, F360 keeps a remnant of the outer edge. Why is this?
I can do the same thing by projecting the surface of this model into my sketch plane and draw a similar intersecting body and it does the same thing. What am I missing?
Attached is my example model and photo of what I'm seeing.
