When I first open my job, components are disjointed, until I try to move one.
NMJ4ME
NMJ4ME
When I first open my job, several groups of components are strewn throughout the workspace. However, if I try to move one of the components (by dragging it with the cursor), then all the components fly together perfectly and everything looks normal again. Thoughts?
I have attached a video example...
Thank you
davebYYPCU
At the beginning of the movie you have a position Capture pending, so saving is done without a Capture, after you re establish a complete model, the movie is again showing a position Capture pending state.  Capture the positions.  End of the Tool bar.
When you move a piece to rebuild - the action of moving a piece is also carried into the end Capture, and now the Assembly is not where it should be.
It appears that you may not have a grounded Component - could not see a pinned Browser component, but you may have something grounded.
Might help...
NMJ4ME
That helped...thanks.
I need to be careful to either revert or capture a position as a fundamental approach during my design. I also need to make sure that joints are used to force the overall integrity of the structure.
