Weird background behavior when sketching on drawing.
itsnotlevel7JAHF
Message 1 of 13
itsnotlevel7JAHF
I've had this problem for quite some time but now it seems to be different or worse.
I have a drawing and im trying to add a sketch and then draw on it but the background turns dark when I try and sketch... video clip attached.
Ideas?
(view in My Videos)
Replies (12)
Message 2 of 13
karina.harper
Autodesk Support
Autodesk Support
Hi @itsnotlevel7JAHF
I think this is related to an issue in the latest update - if you turn off sketch grid for now, I bet this will go away.
Cheers,
Karina
Message 3 of 13
itsnotlevel7JAHF
You are correct, turning off sketch grid works. 😞
Message 4 of 13
itsnotlevel7JAHF
Just so you know, after I close the sketch. If "Layout Grid" is checked at the bottom in Grid and Snaps.... the dark area is still there. But unchecking it makes it go away.
Message 5 of 13
itsnotlevel7JAHF
Sorry, do you want me to open up another issue with this too? It bugs me and has probably done this for a year or so. Please tell me if you see what I see.
(view in My Videos)
Message 6 of 13
g-andresen
I can only advise you to switch off the grid completely and concentrate fully on the geometric shapes in front of you.
Günther
Message 7 of 13
itsnotlevel7JAHF
I appreciate your effort but, I'm fairly certain I'm smart enough to go
down that road without having somebody to tell me to do that.
Message 8 of 13
g-andresen
To clarify:
I am not recommending this as a workaround for this error, but rather as a general optimization of the sketching process.
günther
Message 9 of 13
itsnotlevel7JAHF
Sorry, I dont really know where youre going with this conversation. I replied to the person who was helping me initially. Now all you are doing is talking and saying nothing.
Switching it off and concentrating on the geometric shapes in front of me, as you put it... was a pretty obvious thing to do and it IS a work around for turning off the grid because of a bug in fusion at the moment.
Please dont reply to this, as you are only making me aggravated and it seems you are doing it just to have something to say. Im not sure why youre talking to me right now. Go away.
Message 10 of 13
karina.harper
Autodesk Support
Autodesk Support
FYI @itsnotlevel7JAHF
We fixed the sketch drifting issue in the latest update - it should be resolved when you update to 2603.1.15.
Cheers,
Karina
Message 11 of 13
karina.harper
Autodesk Support
Autodesk Support
@itsnotlevel7JAHF
I do see what you see - does this happen with just this sketch in particular? Feel free to share the design. I have had it happen once in a while, but I don't think we have a way to reproduce what 'causes' it. Any idea?
Cheers,
Karina
Message 12 of 13
donnieapple1101
Community Visitor
Community Visitor
No, you didn't. It is still doing it today with me. How do you fix it. It literally just randomly started turning to dark type of screen.
Message 13 of 13
TheCADWhisperer
@donnieapple1101
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
