webgl Context Lost in generative design preview
zachary_cohen
Message 1 of 10
zachary_cohen
I'm running Fusion on a brand new computer with a high end graphics card and starting with this machine, whenever I click to preview a generative design file I get an error:
WebGL context lost
Unable to recover from software mode. Please restart your browser and reload the viewer
Is there a solution to this? Searching seems to show that this is a rare but reoccurring issue.
Replies (9)
Message 2 of 10
henderh
Hi @zachary_cohen,
Although it isn't the exact message you're seeing, have you tried the steps in the support articles?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Results-of-Simulat...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-We-cannot-sh...
Hope this helps,
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 3 of 10
zachary_cohen
Just tried those suggestions and unfortunately they didn't work.
Thank you for the suggestions though.
Message 4 of 10
henderh
Hi @zachary_cohen,
Could you provide the graphics diagnostics? (Help pull-down > Support and Diagnostics > Graphics Diagnostic)
Also, the diagnostic log files when you see the WebGL error? (Help pull-down > Support and Diagnostics > Diagnostic Log Files)
As a temporary workaround, you should be able to view the outcomes using Fusion in a web browser - https://fusion.online.autodesk.com (FAQ)
Best regards,
Hugh Henderson
Message 5 of 10
zachary_cohen
Hello @henderh,
Below is my graphics diagnostic, and attached is the log.
[GPU Information]
GPU Device: AMD Radeon RX 7900 XTX
GPU RAM: 24576 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 31.0.24019.1006
GPU Driver Date: 02/23/2024
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Message 6 of 10
henderh
Thank you for providing the diagnostics @zachary_cohen.
An issue is logged as Id-152083, for development to investigate further.
Hugh Henderson
Message 7 of 10
kczerwienka
Community Visitor
Community Visitor
Same story for me. However, it worked properly a couple of months ago on the same device, but broke some time ago.
[GPU Information]
GPU Device: AMD RadeonT 780M
GPU RAM: 4096 MB
GPU Driver Version: 31.0.24027.1012
GPU Driver Date: 03/20/2024
Anti Aliasing: On
Object Shadow: Off
Ground Shadow: On
Off
Message 8 of 10
ImCADing_CoryS
Observer
Observer
Hello, I thought that I would chime in with my data as I am having this issue as well.
[GPU Information]
GPU Device: AMD Radeon RX 7800 XT
GPU RAM: 16256 MB
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Selection Display Style: Simple
On
Message 9 of 10
henderh
Thanks for the reports @kczerwienka, and @ImCADing_CoryS.
I've added the additional information to the issue. Knowing this worked in the recent past (using the same hardware) could help development's investigation.
Hugh Henderson
Message 10 of 10
lance.carocci
Hi folks, has this improved after our July 2025 release?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
