webgl Context Lost in generative design preview
zachary_cohen
Message 1 of 9
zachary_cohen
I'm running Fusion on a brand new computer with a high end graphics card and starting with this machine, whenever I click to preview a generative design file I get an error:
WebGL context lost
Unable to recover from software mode. Please restart your browser and reload the viewer
Is there a solution to this? Searching seems to show that this is a rare but reoccurring issue.
Replies (8)
Message 2 of 9
henderh
Hi @zachary_cohen,
Although it isn't the exact message you're seeing, have you tried the steps in the support articles?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Results-of-Simulat...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-We-cannot-sh...
Hope this helps,
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 3 of 9
zachary_cohen
Just tried those suggestions and unfortunately they didn't work.
Thank you for the suggestions though.
Message 4 of 9
henderh
Hi @zachary_cohen,
Could you provide the graphics diagnostics? (Help pull-down > Support and Diagnostics > Graphics Diagnostic)
Also, the diagnostic log files when you see the WebGL error? (Help pull-down > Support and Diagnostics > Diagnostic Log Files)
As a temporary workaround, you should be able to view the outcomes using Fusion in a web browser - https://fusion.online.autodesk.com (FAQ)
Best regards,
Hugh Henderson
Message 5 of 9
zachary_cohen
Hello @henderh,
Below is my graphics diagnostic, and attached is the log.
[GPU Information]
GPU Device: AMD Radeon RX 7900 XTX
GPU RAM: 24576 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 31.0.24019.1006
GPU Driver Date: 02/23/2024
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Message 6 of 9
henderh
Thank you for providing the diagnostics @zachary_cohen.
An issue is logged as Id-152083, for development to investigate further.
Hugh Henderson
Message 7 of 9
kczerwienka
Community Visitor
Community Visitor
Same story for me. However, it worked properly a couple of months ago on the same device, but broke some time ago.
[GPU Information]
GPU Device: AMD RadeonT 780M
GPU RAM: 4096 MB
GPU Driver Version: 31.0.24027.1012
GPU Driver Date: 03/20/2024
Anti Aliasing: On
Object Shadow: Off
Ground Shadow: On
Off
Message 8 of 9
ImCADing_CoryS
Observer
Observer
Hello, I thought that I would chime in with my data as I am having this issue as well.
[GPU Information]
GPU Device: AMD Radeon RX 7800 XT
GPU RAM: 16256 MB
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Selection Display Style: Simple
On
Message 9 of 9
henderh
Thanks for the reports @kczerwienka, and @ImCADing_CoryS.
I've added the additional information to the issue. Knowing this worked in the recent past (using the same hardware) could help development's investigation.
Hugh Henderson
