Virus detection message using fusion 360
Message 1 of 19
I just tried to create a drawing in Fusion 360 and got a virus message from my Symantec software:
"SONAR.Ransom!gen14"   Symantec is pointing to Fusion360.exe file as a source of the virus...  Anyone has an explonation for this message?
Replies (18)
Message 2 of 19
innovatenate
Autodesk Support
Autodesk Support
What's the full path and filename? That looks like the Fusion 360 executable, which should be safe.
You could try adding an exception or whitelisting Fusion 360 in your anti-virus software's settings.
Nathan Chandler
Principal Specialist
Message 3 of 19
This is what Symantec says:
Current Location: c:\users\metro92\appdata\local\autodesk\webdeploy\production\99c9231318b944d70af317142f7dc493a1833b7b\
Category: Application Heuristic
Downloaded by: c:\users\metro92\appdata\local\autodesk\webdeploy\meta\streamer\20170504113200\streamer.exe
Virus Name: SONAR.Ransom!gen14
Current Prevelance: This file has been seen by fewer than 5 Symantec users.
Thanks for looking into this,
Ziggy
Message 4 of 19
alan_erickson
Just had my PC do the same thing except for a slightly different named file.   I added an exception since I assume the file is okay, but it doesn't give me a lot of warm, fuzzy feelings doing it.
Message 5 of 19
innovatenate
Autodesk Support
Autodesk Support
I've logged a report with development to review the issue [UP-34818]. It may not be a bad thing to reach out to Symantec as well. I'll circle back as soon as I find out more information.
Nathan Chandler
Message 6 of 19
Dear Sir/Madam,
I have the same issue too with my fusion360 on a Japanese laptop & windows 8.1 pro. It feels concerning, would it help by re-installing the fusion?
Message 7 of 19
masa.minohara
That looks like the Fusion 360 executable and I believe that is safe. Do you have any issues when launching Fusion? If so, you could try adding an exception or whitelisting Fusion 360, or just hit the Restore(復元) button to see if that helps. At this point, I don't think you need to re-install Fusion.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 8 of 19
Dear Sir,
I still get the virus/worm detected message. It looks worrying that this happen, may I know why this happens and why you suggested I should not worry about it?
Message 9 of 19
masa.minohara
Hi @Anonymous,
Thank you for your response! "fusion360.exe" is the Fusion 360 executable, which is safe and you could try adding an exception or whitelisting Fusion 360 in your anti-virus software's settings.
This has been logged with the development team but we haven't found why Symantec considers Fusion as a risk at the moment. For now I think you may consider reaching out to Symantec for more information. Also, I will post more information as soon as I have one.
Masanobu Minohara
Message 10 of 19
Fusion support suggest it is ok, just the antivirus software has a false positive
Message 11 of 19
matyas.levicek
Observer
Observer
Same alert with Norton 360, It detected it as High Risk and tried to remove it!
Message 12 of 19
This afternoon I also received a warning from Norton about this possible virus:
Just blindly put the file on the whitelist, is not something I encourage. Ofcourse you promote your own product. I understand that. But who is certain this file is 100% clean?
Now you say we (the customers) have to contact Norton to solve this issue? Not really 'customer friendly', in my opinion.
You do not have more information to provide us, as promised, after 3.5 months?
Message 13 of 19
Ya, I wonder why autodesk do not work with Norton to resolve the issue since they have the technical people to talks about it, rather than brushing it aside to users.
Message 14 of 19
matt.pooley
The situation here is that Symantec's anti-virus tool is using heuristics to spot malware type behavior in applications. A couple of actions taken by Fusion 360 can trigger these heuristics, though we don't have enough information to know exactly which combination or timing of actions is the problem. (This is intentional, if Norton shared this information then virus writers would know how to avoid it). Our suspicion is that Fusion's automatic update mechanism, installation in a per-user location and use of multiple executable files are the behaviors which cause it to be flagged.
We have worked with Symantec in the past to get Fusion whitelisted, however the nature of the checks being made mean that their whitelisting can break any time we release an update. (Technical explanation, they use checksums on the executable file as part of the whitelisting criteria, and these change every time we update Fusion).
If individual users report false positives to Symantec then it prompts them to update their whitelist definitions, if a significant number of users report false positives then it may trigger a more lasting change in the heuristics which would prevent future occurrences. I will be reaching out to Symantec to explore options, but would definitely appreciate false positive reports from Symantec customers as supporting data that a change is needed.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 15 of 19
Thank you for your reply, Matt. I appreciate that.
I did (also) report to Symantec regarding this issue, in hope they can reach out to you and you to them.
Let's hope there will be a more permanent fix soon.
Perhaps, in the meantime, a nice workaround could be to send Symantec a new checksum, after an update of the Fusion-executable. In that case, Symantec can distribute that in their periodical update.
Cheers,
Ruud
Message 16 of 19
Hi Matt,
Thank you for your reply and details of the issue behind, this makes it clearer to have better peace of mind.
Andrew
Message 17 of 19
juanaviles
Just adding my experience with this as well.  Also, my update this morning just hangs at 98% complete and never finishes.  Is this part of the same problem?  Here is what's copied to my clipboard:
Filename: fusion360.exe
Threat name: SONAR.AM.C.P!g12Full Path: c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe
____________________________
On computers as of
10/4/2017 at 8:01:22 PM
Last Used
Startup Item
No
Launched
Yes
SONAR Protection monitors for suspicious program activity on your computer.
fusion360.exe Threat name: SONAR.AM.C.P!g12
Locate
Many Users
Thousands of users in the Norton Community have used this file.
New
This file was released 18 days ago.
High
This file risk is high.
Source: External Media
Source File:
fusion360.exe
Network Actions
Event: Symantec IDS signature detected on network traffic (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:12076) No fix attempted
System Settings Actions
Event: Process start (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
\REGISTRY\USER\S-1-5-21-485334879-4012525549-4225510691-1000\Software\Microsoft\Direct3D\MostRecentApplication:Name (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ ceroption.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
Event: Process start: c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\ adexmtsv.exe, PID:7004 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\ mgr40_s1tuno (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ .copy (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ .placeholder (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializei9rwuk1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializekp7ebx1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializejbejxl (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializej91rsh1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ libraryxrcd2h1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ librarykh18wf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\neutron platform\Filelock\ullwlqrn2kdh\ fusion360_2.0.3410_cached_addins.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ fusion360_2.0.3410_cached_addins.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\Synergy\ nlauncher.syncfg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\programdata\Autodesk\Synergy\boost_interprocess\ synhub-forge-7960 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ fusion360_2.0.3410_addins_to_load.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ _analytic-counters.json (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ _analytic-workflows.json (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ flags.json (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\p.login\ jobs.json.lck (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ sessioncache (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\ ogs315097960 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\ogs315097960\ 315097960_texturecache (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ graphicscardinfo.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ __init__.cpython-35.pyc.186073760 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ codecs.cpython-35.pyc.184494192 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ aliases.cpython-35.pyc.186074592 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ mbcs.cpython-35.pyc.184510664 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ utf_8.cpython-35.pyc.186074800 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ latin_1.cpython-35.pyc.186075008 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ io.cpython-35.pyc.184494192 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ abc.cpython-35.pyc.184494576 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _weakrefset.cpython-35.pyc.184511064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ site.cpython-35.pyc.184494768 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ os.cpython-35.pyc.184495536 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ stat.cpython-35.pyc.184495728 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ ntpath.cpython-35.pyc.184495920 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ genericpath.cpython-35.pyc.184511464 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _collections_abc.cpython-35.pyc.186076048 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _sitebuiltins.cpython-35.pyc.184511464 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sysconfig.cpython-35.pyc.184511864 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _bootlocale.cpython-35.pyc.225936208 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ cp1252.cpython-35.pyc.225951792 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ cp437.cpython-35.pyc.225952208 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\Python\packages\adsk\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\python\packages\adsk\__pycache__\ core.cpython-35.pyc.225952416 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ imp.cpython-35.pyc.359038384 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ __init__.cpython-35.pyc.225954496 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ types.cpython-35.pyc.392049072 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ functools.cpython-35.pyc.359189480 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\collections\__pycache__\ __init__.cpython-35.pyc.225955328 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ operator.cpython-35.pyc.225938208 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ keyword.cpython-35.pyc.225938408 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ heapq.cpython-35.pyc.392049840 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ reprlib.cpython-35.pyc.225938808 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ weakref.cpython-35.pyc.225938808 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\collections\__pycache__\ abc.cpython-35.pyc.388735024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ warnings.cpython-35.pyc.392040896 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ machinery.cpython-35.pyc.388736480 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ util.cpython-35.pyc.392041096 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ abc.cpython-35.pyc.392041296 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ contextlib.cpython-35.pyc.392041496 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ tokenize.cpython-35.pyc.392041696 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ re.cpython-35.pyc.392050416 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sre_compile.cpython-35.pyc.392041896 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sre_parse.cpython-35.pyc.392042296 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sre_constants.cpython-35.pyc.392042496 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ copyreg.cpython-35.pyc.392042696 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ token.cpython-35.pyc.359757744 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\python\packages\adsk\__pycache__\ fusion.cpython-35.pyc.225952624 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\python\packages\adsk\__pycache__\ cam.cpython-35.pyc.225953456 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\ version.txt (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\roaming\autodesk\autodesk fusion 360\api\ python (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\CPP\lib\ cam.lib (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\CPP\lib\ core.lib (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\CPP\lib\ fusion.lib (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ traceback.cpython-35.pyc.359505472 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ linecache.cpython-35.pyc.445947952 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ __init__.cpython-35.pyc.367707560 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ decoder.cpython-35.pyc.367707360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ scanner.cpython-35.pyc.367707760 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ encoder.cpython-35.pyc.367707960 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\fathommake\packages\FATHOM\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\fathommake\packages\fathom\__pycache__\ __init__.cpython-35.pyc.384389632 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\fathommake\packages\fathom\__pycache__\ smartquote.cpython-35.pyc.384389864 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\HWTrek\Packages\HWTrek\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\hwtrek\packages\hwtrek\__pycache__\ __init__.cpython-35.pyc.384390328 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\hwtrek\packages\hwtrek\__pycache__\ ui_text.cpython-35.pyc.388756848 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ tempfile.cpython-35.pyc.367709360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ shutil.cpython-35.pyc.446119984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ fnmatch.cpython-35.pyc.388673784 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ posixpath.cpython-35.pyc.388673984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ bz2.cpython-35.pyc.367776752 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _compression.cpython-35.pyc.388673984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ threading.cpython-35.pyc.388674384 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ lzma.cpython-35.pyc.367777328 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ random.cpython-35.pyc.367778096 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ hashlib.cpython-35.pyc.388674984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ uuid.cpython-35.pyc.367778864 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\ctypes\__pycache__\ __init__.cpython-35.pyc.388485376 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ struct.cpython-35.pyc.367778672 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\ctypes\__pycache__\ _endian.cpython-35.pyc.388675584 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\ctypes\__pycache__\ util.cpython-35.pyc.388675784 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ subprocess.cpython-35.pyc.388676384 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ signal.cpython-35.pyc.367779632 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ enum.cpython-35.pyc.388497456 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\__pycache__\ __init__.cpython-35.pyc.388593232 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ __init__.cpython-35.pyc.388404640 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\__pycache__\ __init__.cpython-35.pyc.367625440 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ __future__.cpython-35.pyc.388677184 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ __init__.cpython-35.pyc.367640248 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ connectionpool.cpython-35.pyc.367721008 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\logging\__pycache__\ __init__.cpython-35.pyc.446460576 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ string.cpython-35.pyc.388499184 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ socket.cpython-35.pyc.388499952 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ selectors.cpython-35.pyc.430162968 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ queue.cpython-35.pyc.388500144 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ exceptions.cpython-35.pyc.441694192 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\packages\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\packages\__pycache__\ __init__.cpython-35.pyc.446370096 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\packages\ssl_match_hostname\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\packages\ssl_match_hostname\__pycache__\ __init__.cpython-35.pyc.366067304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ ssl.cpython-35.pyc.388500528 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ ipaddress.cpython-35.pyc.430163968 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ textwrap.cpython-35.pyc.430164368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ base64.cpython-35.pyc.430171120 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\packages\__pycache__\ six.cpython-35.pyc.446370608 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ connection.cpython-35.pyc.441695680 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ datetime.cpython-35.pyc.430163368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ __init__.cpython-35.pyc.437395504 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ client.cpython-35.pyc.437395704 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ __init__.cpython-35.pyc.430165768 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ parser.cpython-35.pyc.430164368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ feedparser.cpython-35.pyc.446463072 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ errors.cpython-35.pyc.437395904 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ message.cpython-35.pyc.437396104 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ uu.cpython-35.pyc.430173232 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ quopri.cpython-35.pyc.430173424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ utils.cpython-35.pyc.437396304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ __init__.cpython-35.pyc.444096976 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ parse.cpython-35.pyc.437397104 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ _parseaddr.cpython-35.pyc.444097808 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ calendar.cpython-35.pyc.437397304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ locale.cpython-35.pyc.442552560 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ charset.cpython-35.pyc.437397304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ base64mime.cpython-35.pyc.444099056 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ quoprimime.cpython-35.pyc.444099264 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ encoders.cpython-35.pyc.437397304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ _policybase.cpython-35.pyc.444099888 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ header.cpython-35.pyc.437398704 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ _encoded_words.cpython-35.pyc.437309696 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ iterators.cpython-35.pyc.437310528 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\util\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ __init__.cpython-35.pyc.444177968 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ connection.cpython-35.pyc.437375024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ request.cpython-35.pyc.440877360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ response.cpython-35.pyc.440877616 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ ssl_.cpython-35.pyc.444007688 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ timeout.cpython-35.pyc.440877872 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ retry.cpython-35.pyc.444008184 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ url.cpython-35.pyc.444008680 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ request.cpython-35.pyc.444008928 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ filepost.cpython-35.pyc.444009176 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ fields.cpython-35.pyc.444009424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ mimetypes.cpython-35.pyc.440840240 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ response.cpython-35.pyc.440840240 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ _collections.cpython-35.pyc.440880176 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ poolmanager.cpython-35.pyc.440880176 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\chardet\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\chardet\__pycache__\ __init__.cpython-35.pyc.361554712 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\contrib\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\contrib\__pycache__\ __init__.cpython-35.pyc.440880432 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\contrib\__pycache__\ pyopenssl.cpython-35.pyc.440880432 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ utils.cpython-35.pyc.440955160 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ cgi.cpython-35.pyc.442554672 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\html\__pycache__\ __init__.cpython-35.pyc.440858624 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\html\__pycache__\ entities.cpython-35.pyc.440858824 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ platform.cpython-35.pyc.440858824 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ certs.cpython-35.pyc.440955856 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ compat.cpython-35.pyc.440956088 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ request.cpython-35.pyc.440859424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ bisect.cpython-35.pyc.439686320 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ error.cpython-35.pyc.439731024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ response.cpython-35.pyc.301586928 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ nturl2path.cpython-35.pyc.439731224 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ cookiejar.cpython-35.pyc.439731424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ copy.cpython-35.pyc.439687088 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ cookies.cpython-35.pyc.439733024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ cookies.cpython-35.pyc.361623832 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ structures.cpython-35.pyc.361624064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ exceptions.cpython-35.pyc.361624064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ models.cpython-35.pyc.361624064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ hooks.cpython-35.pyc.361624992 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ auth.cpython-35.pyc.361625456 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ status_codes.cpython-35.pyc.439573360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ api.cpython-35.pyc.361455376 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ sessions.cpython-35.pyc.361625688 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ adapters.cpython-35.pyc.361626152 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\__pycache__\ sendpart.cpython-35.pyc.387215632 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\logging\__pycache__\ config.cpython-35.pyc.387209016 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\logging\__pycache__\ handlers.cpython-35.pyc.387096064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ pickle.cpython-35.pyc.387104368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _compat_pickle.cpython-35.pyc.387210016 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ socketserver.cpython-35.pyc.387210216 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\ 0qe733sx (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
Event: Process start: c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\WIN64\ adcefwebbrowser.exe, PID:10816 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ jsloadedscriptsinfo (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\neutron platform\Options\ullwlqrn2kdh\ nglobaloptions.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializea1sccl (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\ 91c9c2d0-4423-4e16-b664-04ba539fb061 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ offlinejs.zip (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ activity_feed_offline_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ activity_feed_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ blocked_client_view_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ blocked_os_view_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ common.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ create_branch_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ create_milestone_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ dashboard_rel.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ dashboard_rel.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ data_view_rel.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ data_view_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ error_dialog.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ ipm.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ ipm.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ jquery-1.11.0.min.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ locstrings.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ manage_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ merge_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ simple_sharing_public_link_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ snapshot_viewer_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ myimages (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ arrow.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ close.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ confirmation_normal.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ expired.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ fusion360_purchase_banner.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ loader.gif (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ font (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-bold.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-bolditalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-extrabold.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-extrabolditalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-italic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-light.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-lightitalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-regular.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-semibold.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-semibolditalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ assets (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ alert_icon_gray.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ alert_icon_orange.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ back_16.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ [email protected] (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ back_16_hover.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ bbfolder.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ bbproject.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ branch.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ branch_green.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ cad.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ cam.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_mark.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_mark_16.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_sel.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_unsel.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ chevron_10x14.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ chevron_hover_10x14.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_cross.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_dark.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_dark_gray.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_hover_10.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_normal_10.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_white.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlink.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkactive.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkobject.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkobjectactive.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkpoint.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkpointactive.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ concealment_arrow.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create branch - disabled.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create branch - hover.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create branch.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create milestone - disabled.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create milestone - hover.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create milestone.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
____________________________
File Thumbprint - SHA:
28abba41e453999e01fa828b701a4da1d506d67daeed8a5212b9227b48b860d6
File Thumbprint - MD5:
Not available
Message 18 of 19
matt.pooley
Hi Everyone,
To provide an update, I have spoken to the Symantec support team, they do not offer a proactive whitelisting system at the moment ( https://submit.symantec.com/whitelist/ ), so the best we can do is submit false positive reports, which if accepted will result in definition files being updated within ~72 hours of the submission. we will be able to do this with enough advance notice for our regularly planned updates so that we will avoid alarms, but any hotfixes we release with a rapid turnaround run the risk of happening faster than this process allows, resulting in new false reports.
To apply a broader exclusion on clients, the process documented at https://support.norton.com/sp/en/us/home/current/solutions/kb20100222230832EN_EndUserProfile_en_us can be used to exclude a specific folder, for example setting a SONAR exclusion on the folder %LOCALAPPDATA%\Autodesk\webdeploy\production will avoid future alarms, but will unfortunately expose you to issues if some other malware tries to use our installation area. I would not suggest setting this broad exclusion unless you are very confident in the security of your computer, regularly apply other security patches, and avoid public wi-fi connections.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 19 of 19
Ransomware is not a virus.
http://myspybot.com/redboot-ransomware/
Just in case, read this article, because ransomware is very dangerous!
