Just adding my experience with this as well. Also, my update this morning just hangs at 98% complete and never finishes. Is this part of the same problem? Here is what's copied to my clipboard:
Filename: fusion360.exe
Threat name: SONAR.AM.C.P!g12Full Path: c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe
____________________________
On computers as of
10/4/2017 at 8:01:22 PM
Last Used
Startup Item
No
Launched
Yes
SONAR Protection monitors for suspicious program activity on your computer.
fusion360.exe Threat name: SONAR.AM.C.P!g12
Locate
Many Users
Thousands of users in the Norton Community have used this file.
New
This file was released 18 days ago.
High
This file risk is high.
Source: External Media
Source File:
fusion360.exe
Network Actions
Event: Symantec IDS signature detected on network traffic (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:12076) No fix attempted
System Settings Actions
Event: Process start (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
\REGISTRY\USER\S-1-5-21-485334879-4012525549-4225510691-1000\Software\Microsoft\Direct3D\MostRecentApplication:Name (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ ceroption.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
Event: Process start: c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\ adexmtsv.exe, PID:7004 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\ mgr40_s1tuno (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ .copy (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ .placeholder (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializei9rwuk1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializekp7ebx1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializejbejxl (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializej91rsh1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ libraryxrcd2h1 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ librarykh18wf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\neutron platform\Filelock\ullwlqrn2kdh\ fusion360_2.0.3410_cached_addins.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ fusion360_2.0.3410_cached_addins.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\Synergy\ nlauncher.syncfg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\programdata\Autodesk\Synergy\boost_interprocess\ synhub-forge-7960 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ fusion360_2.0.3410_addins_to_load.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ _analytic-counters.json (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ _analytic-workflows.json (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ flags.json (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\p.login\ jobs.json.lck (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ sessioncache (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\ ogs315097960 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\ogs315097960\ 315097960_texturecache (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ graphicscardinfo.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ __init__.cpython-35.pyc.186073760 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ codecs.cpython-35.pyc.184494192 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ aliases.cpython-35.pyc.186074592 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ mbcs.cpython-35.pyc.184510664 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ utf_8.cpython-35.pyc.186074800 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ latin_1.cpython-35.pyc.186075008 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ io.cpython-35.pyc.184494192 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ abc.cpython-35.pyc.184494576 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _weakrefset.cpython-35.pyc.184511064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ site.cpython-35.pyc.184494768 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ os.cpython-35.pyc.184495536 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ stat.cpython-35.pyc.184495728 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ ntpath.cpython-35.pyc.184495920 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ genericpath.cpython-35.pyc.184511464 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _collections_abc.cpython-35.pyc.186076048 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _sitebuiltins.cpython-35.pyc.184511464 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sysconfig.cpython-35.pyc.184511864 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _bootlocale.cpython-35.pyc.225936208 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ cp1252.cpython-35.pyc.225951792 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\encodings\__pycache__\ cp437.cpython-35.pyc.225952208 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\Python\packages\adsk\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\python\packages\adsk\__pycache__\ core.cpython-35.pyc.225952416 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ imp.cpython-35.pyc.359038384 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ __init__.cpython-35.pyc.225954496 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ types.cpython-35.pyc.392049072 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ functools.cpython-35.pyc.359189480 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\collections\__pycache__\ __init__.cpython-35.pyc.225955328 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ operator.cpython-35.pyc.225938208 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ keyword.cpython-35.pyc.225938408 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ heapq.cpython-35.pyc.392049840 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ reprlib.cpython-35.pyc.225938808 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ weakref.cpython-35.pyc.225938808 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\collections\__pycache__\ abc.cpython-35.pyc.388735024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ warnings.cpython-35.pyc.392040896 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ machinery.cpython-35.pyc.388736480 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ util.cpython-35.pyc.392041096 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\importlib\__pycache__\ abc.cpython-35.pyc.392041296 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ contextlib.cpython-35.pyc.392041496 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ tokenize.cpython-35.pyc.392041696 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ re.cpython-35.pyc.392050416 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sre_compile.cpython-35.pyc.392041896 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sre_parse.cpython-35.pyc.392042296 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ sre_constants.cpython-35.pyc.392042496 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ copyreg.cpython-35.pyc.392042696 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ token.cpython-35.pyc.359757744 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\python\packages\adsk\__pycache__\ fusion.cpython-35.pyc.225952624 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\python\packages\adsk\__pycache__\ cam.cpython-35.pyc.225953456 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\ version.txt (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\roaming\autodesk\autodesk fusion 360\api\ python (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\CPP\lib\ cam.lib (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\CPP\lib\ core.lib (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\API\CPP\lib\ fusion.lib (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ traceback.cpython-35.pyc.359505472 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ linecache.cpython-35.pyc.445947952 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ __init__.cpython-35.pyc.367707560 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ decoder.cpython-35.pyc.367707360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ scanner.cpython-35.pyc.367707760 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\json\__pycache__\ encoder.cpython-35.pyc.367707960 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\fathommake\packages\FATHOM\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\fathommake\packages\fathom\__pycache__\ __init__.cpython-35.pyc.384389632 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\fathommake\packages\fathom\__pycache__\ smartquote.cpython-35.pyc.384389864 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\HWTrek\Packages\HWTrek\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\hwtrek\packages\hwtrek\__pycache__\ __init__.cpython-35.pyc.384390328 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\hwtrek\packages\hwtrek\__pycache__\ ui_text.cpython-35.pyc.388756848 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ tempfile.cpython-35.pyc.367709360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ shutil.cpython-35.pyc.446119984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ fnmatch.cpython-35.pyc.388673784 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ posixpath.cpython-35.pyc.388673984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ bz2.cpython-35.pyc.367776752 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _compression.cpython-35.pyc.388673984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ threading.cpython-35.pyc.388674384 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ lzma.cpython-35.pyc.367777328 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ random.cpython-35.pyc.367778096 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ hashlib.cpython-35.pyc.388674984 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ uuid.cpython-35.pyc.367778864 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\ctypes\__pycache__\ __init__.cpython-35.pyc.388485376 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ struct.cpython-35.pyc.367778672 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\ctypes\__pycache__\ _endian.cpython-35.pyc.388675584 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\ctypes\__pycache__\ util.cpython-35.pyc.388675784 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ subprocess.cpython-35.pyc.388676384 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ signal.cpython-35.pyc.367779632 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ enum.cpython-35.pyc.388497456 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\__pycache__\ __init__.cpython-35.pyc.388593232 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ __init__.cpython-35.pyc.388404640 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\__pycache__\ __init__.cpython-35.pyc.367625440 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ __future__.cpython-35.pyc.388677184 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ __init__.cpython-35.pyc.367640248 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ connectionpool.cpython-35.pyc.367721008 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\logging\__pycache__\ __init__.cpython-35.pyc.446460576 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ string.cpython-35.pyc.388499184 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ socket.cpython-35.pyc.388499952 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ selectors.cpython-35.pyc.430162968 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ queue.cpython-35.pyc.388500144 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ exceptions.cpython-35.pyc.441694192 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\packages\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\packages\__pycache__\ __init__.cpython-35.pyc.446370096 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\packages\ssl_match_hostname\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\packages\ssl_match_hostname\__pycache__\ __init__.cpython-35.pyc.366067304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ ssl.cpython-35.pyc.388500528 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ ipaddress.cpython-35.pyc.430163968 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ textwrap.cpython-35.pyc.430164368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ base64.cpython-35.pyc.430171120 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\packages\__pycache__\ six.cpython-35.pyc.446370608 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ connection.cpython-35.pyc.441695680 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ datetime.cpython-35.pyc.430163368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ __init__.cpython-35.pyc.437395504 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ client.cpython-35.pyc.437395704 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ __init__.cpython-35.pyc.430165768 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ parser.cpython-35.pyc.430164368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ feedparser.cpython-35.pyc.446463072 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ errors.cpython-35.pyc.437395904 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ message.cpython-35.pyc.437396104 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ uu.cpython-35.pyc.430173232 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ quopri.cpython-35.pyc.430173424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ utils.cpython-35.pyc.437396304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ __init__.cpython-35.pyc.444096976 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ parse.cpython-35.pyc.437397104 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ _parseaddr.cpython-35.pyc.444097808 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ calendar.cpython-35.pyc.437397304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ locale.cpython-35.pyc.442552560 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ charset.cpython-35.pyc.437397304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ base64mime.cpython-35.pyc.444099056 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ quoprimime.cpython-35.pyc.444099264 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ encoders.cpython-35.pyc.437397304 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ _policybase.cpython-35.pyc.444099888 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ header.cpython-35.pyc.437398704 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ _encoded_words.cpython-35.pyc.437309696 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\email\__pycache__\ iterators.cpython-35.pyc.437310528 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\util\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ __init__.cpython-35.pyc.444177968 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ connection.cpython-35.pyc.437375024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ request.cpython-35.pyc.440877360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ response.cpython-35.pyc.440877616 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ ssl_.cpython-35.pyc.444007688 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ timeout.cpython-35.pyc.440877872 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ retry.cpython-35.pyc.444008184 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\util\__pycache__\ url.cpython-35.pyc.444008680 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ request.cpython-35.pyc.444008928 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ filepost.cpython-35.pyc.444009176 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ fields.cpython-35.pyc.444009424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ mimetypes.cpython-35.pyc.440840240 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ response.cpython-35.pyc.440840240 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ _collections.cpython-35.pyc.440880176 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\__pycache__\ poolmanager.cpython-35.pyc.440880176 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\chardet\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\chardet\__pycache__\ __init__.cpython-35.pyc.361554712 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\Api\internaladdins\MakeTime\Packages\requests\packages\urllib3\contrib\ __pycache__ (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\contrib\__pycache__\ __init__.cpython-35.pyc.440880432 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\packages\urllib3\contrib\__pycache__\ pyopenssl.cpython-35.pyc.440880432 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ utils.cpython-35.pyc.440955160 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ cgi.cpython-35.pyc.442554672 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\html\__pycache__\ __init__.cpython-35.pyc.440858624 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\html\__pycache__\ entities.cpython-35.pyc.440858824 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ platform.cpython-35.pyc.440858824 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ certs.cpython-35.pyc.440955856 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ compat.cpython-35.pyc.440956088 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ request.cpython-35.pyc.440859424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ bisect.cpython-35.pyc.439686320 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ error.cpython-35.pyc.439731024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\urllib\__pycache__\ response.cpython-35.pyc.301586928 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ nturl2path.cpython-35.pyc.439731224 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ cookiejar.cpython-35.pyc.439731424 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ copy.cpython-35.pyc.439687088 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\http\__pycache__\ cookies.cpython-35.pyc.439733024 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ cookies.cpython-35.pyc.361623832 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ structures.cpython-35.pyc.361624064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ exceptions.cpython-35.pyc.361624064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ models.cpython-35.pyc.361624064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ hooks.cpython-35.pyc.361624992 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ auth.cpython-35.pyc.361625456 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ status_codes.cpython-35.pyc.439573360 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ api.cpython-35.pyc.361455376 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ sessions.cpython-35.pyc.361625688 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\requests\__pycache__\ adapters.cpython-35.pyc.361626152 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\api\internaladdins\maketime\packages\__pycache__\ sendpart.cpython-35.pyc.387215632 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\logging\__pycache__\ config.cpython-35.pyc.387209016 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\logging\__pycache__\ handlers.cpython-35.pyc.387096064 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ pickle.cpython-35.pyc.387104368 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ _compat_pickle.cpython-35.pyc.387210016 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\python\lib\__pycache__\ socketserver.cpython-35.pyc.387210216 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\ 0qe733sx (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
Event: Process start: c:\Users\Juan\AppData\Local\Autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\WIN64\ adcefwebbrowser.exe, PID:10816 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\autodesk fusion 360\ullwlqrn2kdh\ jsloadedscriptsinfo (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Roaming\Autodesk\neutron platform\Options\ullwlqrn2kdh\ nglobaloptions.xml (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\Users\Juan\AppData\Local\Autodesk\Common\material library\17071701\proteinrun\mgr40_s1tuno\ deserializea1sccl (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\ 91c9c2d0-4423-4e16-b664-04ba539fb061 (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ offlinejs.zip (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ activity_feed_offline_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ activity_feed_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ blocked_client_view_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ blocked_os_view_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ common.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ create_branch_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ create_milestone_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ dashboard_rel.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ dashboard_rel.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ data_view_rel.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ data_view_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ error_dialog.css (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ ipm.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ ipm.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ jquery-1.11.0.min.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ locstrings.js (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ manage_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ merge_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ simple_sharing_public_link_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ snapshot_viewer_rel.html (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ myimages (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ arrow.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ close.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ confirmation_normal.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ expired.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ fusion360_purchase_banner.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\myimages\ loader.gif (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ font (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-bold.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-bolditalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-extrabold.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-extrabolditalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-italic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-light.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-lightitalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-regular.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-semibold.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\font\ opensans-semibolditalic.ttf (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\ assets (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ alert_icon_gray.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ alert_icon_orange.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ back_16.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ [email protected] (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ back_16_hover.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ bbfolder.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ bbproject.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ branch.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ branch_green.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ cad.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ cam.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_mark.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_mark_16.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_sel.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ check_unsel.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ chevron_10x14.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ chevron_hover_10x14.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_cross.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_dark.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_dark_gray.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_hover_10.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_normal_10.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ close_white.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlink.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkactive.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkobject.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkobjectactive.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkpoint.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ commentlinkpointactive.png (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ concealment_arrow.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create branch - disabled.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create branch - hover.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create branch.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create milestone - disabled.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create milestone - hover.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
c:\users\juan\appdata\local\temp\neutron\91c9c2d0-4423-4e16-b664-04ba539fb061\assets\ create milestone.svg (Performed by c:\users\juan\appdata\local\autodesk\webdeploy\production\5308b208c635b362e208fc86d5a97f2fcda381e2\fusion360.exe, PID:7960) No fix attempted
____________________________
File Thumbprint - SHA:
28abba41e453999e01fa828b701a4da1d506d67daeed8a5212b9227b48b860d6
File Thumbprint - MD5:
Not available
