Very ugly mesh rendering
jan.picko
jan.picko
last week we are experiencing very bad mesh rendering results.
It used look like this:
But now it looks like this:
What is wrong?
@jhackney1972
@TrippyLighting
J. Picko
TrippyLighting
Without the model there is not much we can do.
Is that a could, local, or canvas render ?
jan.picko
Both are local renders.
But cloud render is also ugly.
File is here.
TrippyLighting
A canvas render of the object looks fine, just like the first image you posted.
A local render looks ... bad!
I believe you are seeing the same or at least a very similar effect than the user in this thread.
@Phil.E Can you forward this to the render team for investigation?
jan.picko
Weird is the fact, that first and second image are rendered the very same way, the second just 10 months later. So where could be the issue?
jan.picko
And the issue is about mesh object only, other objects renders just fine.
longfei.zhang
can you clarify more about that first and second image are rendered the very same way, do you mean those two images are rendered using local render?(instead of in-canvas render)
