Usage Limits Exceeded After Renewing my Startup License
Nicki.svendsen
Message 2 of 8
Nicki.svendsen
Hi
I just renewed my startup license, and now I can't create a new project!
I tried using the steps in the thread: "Error: "Usage Limits Exceeded" when trying to save or create a new project in Fusion 360", but it did not work!
Any one knows what to doo?
Kind regards Nicki
Replies (7)
Message 1 of 8
Nicki.svendsen
Hi
Kind regards Nicki
Message 3 of 8
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Nicki.svendsen ,
Thanks for posting! Please try the following:
  1. Click your name in the top-right hand of Fusion 360 and select Sign Out
  2. Open a Web Browser and navigate to A360
  3. Sign in with your email address and password
  4. Once signed in, create a new project manually here.
  5. Sign back into Fusion 360
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 4 of 8
Nicki.svendsen
It does not work! Still get the same error message from web browser!Udklip2.PNG
Message 5 of 8
julia.paganucci
Autodesk Support
Autodesk Support
Sometimes it takes a little time for the subscription to sync up. I just checked your account and everything seems to be fine- can you please check again?
Thanks!
Julia Paganucci
Message 6 of 8
Hi Julia...can you please clarify Autodesk's official policy regarding the renewal of a free Startup license? If I am a hobbyist who uses Fusion 360 solely and exclusively for the purpose of creating my own models for non-commercial purposes, can I renew my free one-year Startup license on a perpetual basis (pending, of course, on Autodesk's prerogative to change this policy)? If so, where on the Autodesk website is this policy explicitly stated, i.e. the part about the ability for a Startup licensee to renew their free one-year Startup license at the expiration of the one year. Thank you.
Message 7 of 8
julia.paganucci
Autodesk Support
Autodesk Support
hi @Anonymous .
You can definitely renew your hobbyist license!
If you look at this article, you can renew your license yearly as long as you still maintain the qualifications.
Julia Paganucci
Message 8 of 8
Thank you very much Julia. Both of those articles are very helpful! My only suggestion is that Autodesk formally state its policy to renew startup licenses in its EULA and/or on its legal terms webpage. Obviously, Autodesk is free to modify its licensing terms at will, but if renewing startup licenses is its current policy, it should state so in its legal terms. Doing so would avoid much confusion and explaining regarding this issue. Is this something you would be able to escalate within your organization? Again, thanks much for your help!
