Update / refresh part, assembly, drawing
Bernd_CAD
Bernd_CAD
Now I worked some hours with Fusion.
On thing which costs me a lot of time is to update the project after a change in a part.
I have a drawing of a top assembly. Under the top assembly is a sub assembly with some parts.
Now I make a small change in a part and want to check in the drawing of the top assembly that everything fits.
So I have to save the part where I made the change.
Then I have to open the sub assembly and update it. Also save the sub assembly.
Now I have to go into the top assembly upate and save it.
Then I go to the drawing and update it.
Now I see the result.
Is there a way to get an automated update function throug the project? This costs a lot of time. Even it is not possible to skip one of the mentioned steps.
Thanks and best regards,
Bernd
innovatenate
Autodesk Support
Autodesk Support
1. Say you have A (version1) ----xrefs----> B (version1) ----xrefs----> C (version1).
2. Now C (version2) is saved separately.
3. Then A (version1) is opened. If you do Get all Latest (command in the upper toolbar), B (version1) is modified to reference Cv2. When A (version 1) is saved, both A (version2) and B (version2) are created so that C (version2) is used. So child B is modified in this special case, also known as deep update.
I haven't done any verification of how deep update behaves with drawing assets.
Have you tested just modifying the "part" (C in the above example) and then doing a Get All Latest command to see how the drawing updates?
Nathan Chandler
Principal Specialist
