Text tool forgets parameters
daniel.ashbrook
daniel.ashbrook
If I set the height of text in a sketch to a parameter, when I change the parameter the text height doesn't change. Instead, it has the value of the original parameter substituted.
jeff_strater
Thanks, @daniel.ashbrook,
This is a known limitation/bug right now.  However, we are working on this very problem currently.  The unfortunately clumsy workaround, until this is resolved, is to add a dimension to the text box (it has to be point-to-point right now, there is a bug that you cannot select the box line...), and tie that to the parameter:
Jeff
Jeff Strater
Engineering Director
