Unable to use compare versions feature on Fusion 360 web
Luis_Garcia
Luis_Garcia
I am trying to compare two different versions with the compare utility on Fusion 360 web (Autodesk360)
When the version selection dialog pops up and I select the desired versions, it gives the following messages:
It translates to: No visible/valid elements found to compare.
It gives this message no matter which versions I choose.
Any guesses on I might be doing wrong/not be working?
Cheers
sutherland-
Hi @Luis_Garcia
Is it possible that you share the model here?
Also, is your model made from solids or meshes?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Luis_Garcia
I am attaching the file.
Thank you
sutherland-
Have you tried to compare your model with other versions? Like v16 and v12 as an example?
It seems like it is some fault within the F360 web, since I tried to see if it will show any changes when I created a cube, saved it as v1, then created another sphere next to the first cube as v2 and it shows the same error:
Best regards,
Level  sutherland-
Member
Luis_Garcia
Yes, I have tried comparing different versions and all of them report the same message.
How should I report this to Autodesk for review?
Thank you
sutherland-
Please try to use this link and follow the steps that you will see in the on the screen.
Best regards,
Level  sutherland-
Member
oyvindTMNSU
any news on this? I have the same problem
