Unable to fillet in sketch
I traced outlines from a photo for the shapes i want to use with splines. I then used the offset tool to offset the original splines that were used, removed depenancies linking offset to splines and then removed the original splines. I joined up the offsets to make contained shapes once more and saved it. I was then able to successfully use fillet tool as normal, however after a couple of hours i realised i put too many fillets in where they would not be needed. i loaded the file 2 versions before the lastest and before i started the fillets and saved with different file name so it was not read only. This time I am unable to fillet anything in my sketch, even drawing a perpendicular, straight L shape with all dependancies removes it displays the same behavior: Fusion 360 hamgs for about 5 seconds, then it errors with Error: Failed to solve. Please try revising dimensions or constraints. It is probably just a simple easy thing that i am missing as to why it worked the first time flawlessly yet now the fillet tool is not working at all.
g-andresen
can you say which elements are affected?
günther
Forgive me for perhaps not understanding, but if you are talking about elements as to mean the parts of my sketch then it is all of it. I can't create fillets in any part of my sketch due to the hanging  then i get this Error: Failed to solve. Please try revising dimensions or constraints.
bump
